Sitaring Issue with my D-1
6l6
Real Name: Bill
Post: # 2415Post 6l6
Wed Apr 29, 2020 12:35 am
In 1999 I bought a new Collings D-1 and I've loved every minute of playing it.
However...
For some reason it's developed a "sitar" sound on the Second ("B") string. I have used D'Addario PB strings in Light gauge since the day it was new and I love the sound they produce.
I've tried reseating the second string and replacing it several times, but the sitar effect keeps rearing its ugly head.
Any ideas I should try?
Thanks,
Bill
dadgad6strings
Re: Sitaring Issue with my D-1
Post: # 2416Post dadgad6strings
Wed Apr 29, 2020 3:05 am
It's the action.
Have you been keeping it humidified? This time of year, the relief can change a bit and/or the top sinks and those changes can be enough to lower the strings as to where they are touching the frets just a smidge, hence the sitar sound!
First I would say make sure that it's properly humidified, then, check the relief and the action at the 12th fret. If it just needs to be re-hydrated, that could take care of the problem.
If it has been humidified, then making a minor relief adjustment would probably be all you need. If in the event you're not sure and or are not comfortable making adjustments yourself, take it to a qualified tech.
It does sound to me to be the humidity levels and your guitar is just experiencing the normal changes that come with the seasonal changes.
dadgad6strings
Post: # 2417Post dadgad6strings
Wed Apr 29, 2020 3:08 am
Having said all that in the previous post, let me add that if it's not related to the humidy there is always the possibility that a fret is loose or something and fret level is needed. I don't think that's the case though because it sounds like it's been playing fine up to the point that you started experiencing the Ravi Shankar Sitar sound.
6l6
Real Name: Bill
Post: # 2418Post 6l6
Wed Apr 29, 2020 4:43 am
Thanks for your help!
Bill
Derek
Post: # 2419Post Derek
Wed Apr 29, 2020 6:31 am
Sitar on open string and most frets then take a look at the saddle top where the string sits for a bit of a groove developing.
ahumphrey79
Real Name: Andrew Humphrey
Post: # 2445Post ahumphrey79
Wed May 06, 2020 2:14 pm
I agree with checking the saddle for a groove or maybe the string is slightly binding at the nut. My dad has a Taylor 914 and he had a similar problem. Turned out he needed to have the neck re-shimmed. I would say it is time for a luthier to give it a look over. I've also seen this problem on a 2016 J 45 vintage and it was not seated in the nut properly.
