Waverly tuner alternatives for OM1?
dadgad6strings
Post: # 5600Post dadgad6strings
Mon Jun 06, 2022 11:29 am
I have a Collings with the standard 16:1 ratio Waverlys. They tune fine but they're a bit tight and I'd prefer the higher ratio.
They now make them in the 21:1 high ratio version but not with the ebony buttons.
I know it's just aesthetics but it matters.
Are there other direct fit high quality, high ratio options?
Re: Waverly tuner alternatives for OM1?
Post: # 5603Post Greg Y
Mon Jun 06, 2022 8:09 pm
If your Waverly's are tight or some of them are....contact StewMac. They've either replaced or reworked tuners for me in the past.
dariustdog
Real Name: Tony
Post: # 5656Post dariustdog
Tue Jun 28, 2022 2:52 am
You can get the high ratios Waverleys with ivoroid buttons. You can get ebony buttons as well, so you could pretty easily replace the ivoroid buttons with ebony.. Not sure if the butterbean buttons are removable/replaceable.
dadgad6strings
Post: # 5659Post dadgad6strings
Tue Jun 28, 2022 12:21 pm
I'm pretty sure you can't remove the buttons. I don't see a screw on the tuners.
