Temperature change
Temperature change
Hey, I treat my 2015 CJ like royalty. At times (wife napping) I want to play in another room, but typically I keep the temperature down in that room (New England heat season - July, August, winter), a difference of say 8-10 degrees. Humidity is close to 50% in both rooms. I find no information that specific anywhere. Any thoughts? Thanks.
Re: Temperature change
Ten degrees should not be any problem for wood. At least not unless the temperatures are less than 50F or greater than 80F. Ten percent change in humidity or even more for a few hours is again probably not a factor if in the sweet spot range between 40% RH and 60%.
a 10 degree temperature change should not be a problem. The instrument would possibly need to be retuned but will be fine. Players that play outdoors do it all the time. From an air conditioned green room to an outdoor stage and then back again.
